Need harness help, LT1 to LS(LQ4) swap
Old 01-09-2013, 01:33 AM
Jc803's Avatar
Default Need harness help, LT1 to LS(LQ4) swap
I'm doing a turbo LQ4 swap in my 96 Z-28. Just a couple questions.
1. Whats the easiest way to do the harness and PCM to get it running? Splice LT harness, splice LS harness, buy one already fabbed?
2. I have already deleted ABS and TCS (using manual throttle cable and line lock), EGR, air injection, AC, heat, PS, fog lights, and a bunch of other electrical stuff I'm not using anymore. I also have a t-56 that I'm sending in to have the input shaft and bell housing changed. With all this said, will this make making my own harness easier or is all this irrelevent
Old 01-09-2013, 01:36 AM
Jc803's Avatar
Also I'm deployed in Afghanistan right now and it takes 10 minutes to load one page so searching around for answers or diagrams isnt practial. If anyone has links that would help me that would be great. Thanks
Old 01-09-2013, 06:58 AM
Old Geezer's Avatar
Easiest way??? Buy a harness.
Old 01-09-2013, 10:28 PM
Jc803's Avatar
Thanks for the advise. Sounds good to me. Any links where to or suggestions?
Old 01-10-2013, 07:22 AM
Old Geezer's Avatar
Talking There are..
several board sponsors that have what you want.
PSI, Speartech, etc.
Take a look at the top of the forum, under sponsors...Run a search there.
Old 01-10-2013, 08:34 AM
Jc803's Avatar
Thanks. Easy enough
Quick Reply: Need harness help, LT1 to LS(LQ4) swap
