71 camaro ls1/4l40 swap to t-56
Old 02-24-2013, 02:01 AM
WTR's camaro's Avatar
Default 71 camaro ls1/4l40 swap to t-56
hey yall about a month ago i got a ls1/4l60 out of a 98 ss. i found a t-56 out of a 01 z 28. i have read that you can use the smae wiring harness. but i have also read that thr 98 harnesses need to be replaced. would if be in my best interest to find a ls1 manual pcm? instead of flashing this one and then re wiring it?
thanks for all the advice
Walker
Old 02-24-2013, 06:47 AM
98Camarod's Avatar
IIRC, you can run the auto harness on a manual, but not vice versa. I could be completely wrong though. I researched this back when I first got my car because I originally wanted a t56.
Any particular reason you want a t56?
Old 02-24-2013, 06:57 AM
always had a auto and i just want a 6 speed. was looking into a super T-10 to go in it but mateing that up to the ls1 would be a pita. plus with a stick you dont have to worry with stalls. i really think i might just try and find a 99+ harness to mate with this that way everything will match up and i wont have to splice into the wires. im just looking for some tech advice before i go dropping money on it.
Old 02-25-2013, 11:34 AM
wait4me's Avatar
It will work but you will need to pin out the ecm to get Reverse lockout trigger. The vehicle speed sensor should plug in. Then you will have to wire in your Reverse tail lights as well on the side of the transmission.
wait4me's Avatar
Also the pcm can just be flashed to what ever you want, auto, manual, ect..
Old 02-27-2013, 10:36 AM
well im just wondering if it would save me alot of time and hassle if i just found a newer manual pcm and harness for the swap?
Old 02-27-2013, 11:42 AM
wait4me's Avatar
Why bother. The computers are IDENTICAL.
The pins needed for your auto harness are like 13 dollars.
Old 02-28-2013, 01:16 AM
well cause mine is a 98 model ls1. i have heard that it is best to swap to a 99+
Old 02-28-2013, 09:50 AM
wait4me's Avatar
Turbo setup maybe, but not for just heads, cam and small mods...
Quick Reply: 71 camaro ls1/4l40 swap to t-56
