Can you switch ecm from one cammed car to another?
Old 03-01-2013, 11:55 PM
VandykeT/A's Avatar
Default Can you switch ecm from one cammed car to another?
My Camaro is bolt ons/Torquer 2 M6 car. My friends car is tore down and will be a 228r car/ bolt ons minus a LS6 intake. Its a stick car as well. My question is since we have his computer in the mail getting a mail order tune. What are the odds I could take my dyno tuned Torquer 2 computer and use in his car just to start to let idle? Will it work? Is it safe?
Old 03-02-2013, 06:56 AM
MUSTANGBRKR02's Avatar
You can do it as long as they are both 99-02 or 98's. It won't be perfect but to start it there shouldn't be a problem.
Old 03-02-2013, 07:30 AM
VandykeT/A's Avatar
They're both 2000s actually. We just wanted to let it idle for a little while to check for leaks and let the valve springs get a couple heat cycles before his came and he could take it straight home. It won't be moved with it just started in the driveway. Thanks
Old 03-02-2013, 03:41 PM
MontecarloDrag's Avatar
You can, you only need to do a VATS relearn (unless it is disabled in the tune)
Old 03-02-2013, 09:42 PM
VandykeT/A's Avatar
what do you mean vats relearn? Both cars have the key switches bypassed with resistors but not turned off in the ecm. How do I do that?
Quick Reply: Can you switch ecm from one cammed car to another?
