95# injectors help with efi live flow rate table
Old 03-07-2013, 11:29 PM
Wicked 1's Avatar
Default 95# injectors help with efi live flow rate table
I'm running a 1 to 1 boost regulator at 50 psi
Old 03-08-2013, 08:53 AM
wait4me's Avatar
What injector brand or part number,
What is that fuel lb rating at? 3 bar or 4?
Old 03-11-2013, 02:27 PM
Wicked 1's Avatar
Acceleronics delphi 95# at 43psi 2 bar tune
Old 03-11-2013, 02:57 PM
wait4me's Avatar
ok. Yeah I have used those ones before. They lock up when you go to high on fuel pressure I found out. They are a disc style.
As for settings B4001,
96.530000
96.632937
96.735875
96.838812
96.941750
97.044687
97.147625
97.250562
97.353500
97.456437
97.559375
97.662312
97.765250
97.868187
97.971125
98.074062
98.177000
Table b3701
LABELS Battery Volts {link: GM.VOLTS}
Manifold Vacuum PSI {link: GM.MANVAC} 11.0 11.5 12.0 12.5 13.0 13.5 14.0
0.0 0.757604 0.722878 0.692826 0.617289 0.534442 0.459718 0.365500
0.7 0.803185 0.751306 0.696887 0.628660 0.563682 0.491395 0.432040
1.5 0.813028 0.759428 0.701760 0.641656 0.571805 0.510076 0.442695
2.2 0.813776 0.755367 0.709070 0.644092 0.582363 0.513325 0.454130
2.9 0.779695 0.743184 0.711507 0.646529 0.584800 0.523071 0.456599
3.6 0.819558 0.767550 0.713944 0.656276 0.587237 0.525508 0.459068
4.4 0.838367 0.776485 0.726939 0.659525 0.596983 0.527132 0.467190
5.1 0.831805 0.780546 0.727751 0.670083 0.599420 0.529569 0.468814
5.8 0.797724 0.761052 0.737498 0.671708 0.600232 0.536879 0.468814
6.5 0.843241 0.784607 0.738310 0.672520 0.600232 0.528757 0.468002
7.3 0.853928 0.791105 0.739935 0.671708 0.599420 0.527132 0.458223
8.0 0.844085 0.782982 0.728564 0.669271 0.597796 0.525508 0.456567
8.7 0.800225 0.760240 0.726939 0.660337 0.589673 0.525508 0.455723
9.4 0.846554 0.784607 0.728564 0.661149 0.596983 0.525508 0.455723
10.2 0.862580 0.801664 0.740747 0.670896 0.598608 0.526320 0.455723
10.9 0.862580 0.796790 0.740747 0.672520 0.599420 0.526320 0.455723
11.6 0.805098 0.767550 0.738310 0.672520 0.599420 0.526320 0.455723
Table B4003
0.653000
0.653000
0.653000
0.653000
0.653000
0.653000
0.653000
0.653000
0.653000
0.653000
0.653000
0.653000
0.653000
0.653000
0.653000
0.653000
0.653000
0.653000
0.653000
0.653000
0.653000
B4005
0.325075
0.339208
0.320363
0.292096
0.263829
0.235561
0.207294
0.190020
0.207294
0.197872
0.179027
0.160182
0.142907
0.130344
0.114640
0.103647
0.095795
0.092654
0.084802
0.076950
0.073809
0.067528
0.065957
0.064387
0.058105
0.054964
0.048683
0.047112
0.047112
0.047112
0.045542
0.039260
0.037690
0.037690
0.037690
0.037690
0.037690
0.036119
0.029838
0.028267
0.028267
0.028267
0.028267
0.028267
0.028267
0.028267
0.028267
0.028267
0.026697
0.020415
0.018845
0.018845
0.018845
0.018845
0.018845
0.018845
0.018845
0.018845
0.018845
0.018845
0.018845
0.018845
0.018845
0.018845
0.017275
0.010993
0.009422
Old 03-11-2013, 03:23 PM
Wicked 1's Avatar
thanks that will help me alot what psi did you have problams at
will the tables change going to e85 im on 91 now
Old 03-11-2013, 03:27 PM
wait4me's Avatar
Looks like they where doing bad at about 74psi
wait4me's Avatar
Those tables shouldn't change much with e85. You just have to fix your Maf and VE and your stoich point in the tune. Injector tables should stay the same.
Old 03-11-2013, 03:43 PM
Wicked 1's Avatar
thanks for the info wait4me
Quick Reply: 95# injectors help with efi live flow rate table
