HPTuners....adding percentages across the table?
Old 03-22-2013, 08:22 AM
Wicked69's Avatar
Default HPTuners....adding percentages across the table?
Before I mess up my tune I just wanted to verify. If I click on the upper left hand corner of my main VE table, that will highlight the entire table. We have just switched from E51 to E80 this week. I need to ad 12 percent more fuel across the board. Normally, .12 is twelve percent but when you type .12 in the box and click the X (multiply) button I don't think it is adding 12 percent. Do you need to type in 1. first for any percentages? For example: If I want to ad 12 percent then I need to type in 1.12 in the box and then click the X (multiply) button?
Thanks.
Old 03-22-2013, 08:36 AM
sweet-94z28's Avatar
To increase 12%, enter 1.12 then hit multiply. Should do the trick!
Multiplying by .12 will give you only 12% of what you had. You need 12% more so you must take 100% (1.00), then add 12% (.12) so 1.12 will get you there!
Old 03-22-2013, 08:54 AM
Exidous's Avatar
Can't you change the stoich AFR to what E80 needs and the computer will do the rest? Assuming the tune was on with reg gas.
Quick Reply: HPTuners....adding percentages across the table?
