efi live v1 trouble
Old 03-28-2013, 08:45 AM
outkast6991's Avatar
Default efi live v1 trouble
I need a little help from the experts. I'm trying to set up my v1 so i can log without the laptop in the car. Using an old post from Joecar and the owners manual i followed the steps described. When i connect the cable to the car without the laptop and hit the record button to validate the PIDs the "log" button turns green for about 15 sec then shuts off. I then go into the read logged data screen and it shows the status of v1 as "validating pids" mode. I've done this about 10 times but it won't switch. When i go to the "program pids" menu it gives me a DMA suffix warning (normal?) then says i have no selected channels? I'm pretty lost and could really use some help. With the laptop in the car it still scans with no issues
Old 03-28-2013, 07:11 PM
BLK02WS6's Avatar
Hey Matt - did you program the pids into the V1 using the laptop prior to blackbox logging?
Sent you an email with an attachment and some explanation...
Old 04-02-2013, 09:55 AM
joecar's Avatar
Also try removing the DMA pid from the list of black box pids.
Old 04-02-2013, 01:53 PM
I got it to log but it stops at 600 frames. Not sure why yet
Old 04-02-2013, 07:07 PM
joecar's Avatar
There is a setting for the log time period...
joecar's Avatar
Post a screenshot.
Old 04-04-2013, 04:30 PM
joecar's Avatar
outkast,
did you figure it out...?
if not, then I'll have to dig up my old V1 and see what the scantool page shows.
Old 04-04-2013, 06:23 PM
outkast,
sorry joe i missed your post. I think i did figure it out but havent had a chance to try a log yet. it was right in front of my face the whole time. it actually says something like "maximum frames per log". I'll report back when i try it out
Old 04-05-2013, 06:42 PM
well it didn't work. even though it now says 30,000 frames it still stops at 600. any help is greatly appreciated
Attached Thumbnails efi live v1 trouble-73979_10151548543877349_2045145719_n.jpg   efi live v1 trouble-537895_10151548545567349_1874432076_n.jpg
Old 04-06-2013, 11:36 PM
joecar's Avatar
Can you do Ctrl-PrtScrn and save to file and post that...
Old 04-06-2013, 11:37 PM
joecar's Avatar
Also, first select Fast mode.
Old 04-06-2013, 11:38 PM
for some reason it won't work on my laptop. thats why i took a cell pic of those 2 pages. sorry for the blurry pics
Old 04-06-2013, 11:45 PM
joecar's Avatar
Set Max Frames Per Log to zero, this will keep recording going until V1 flash memory is full
( see scantool user manual pdf pages 110-112.
Old 04-06-2013, 11:46 PM
joecar's Avatar
Download/install Greenshot from sourceforge, it makes screenshots a snap (pun intended).
Old 04-06-2013, 11:51 PM
thanks! i'll try both in the morning and report back
Old 04-06-2013, 11:53 PM
joecar's Avatar
Make sure you select Fast mode.
Old 04-07-2013, 12:11 AM
will do
Old 04-08-2013, 06:15 PM
Well here are a couple screen shots. I made the changes stated above but I'm obviously missing something because on the status page the new info isn't there. It still only logs for 600 frames
Attached Thumbnails efi live v1 trouble-2013-04-08-19_06_05-greenshot.jpg   efi live v1 trouble-2013-04-08-19_07_11-greenshot.jpg
Old 04-09-2013, 01:21 AM
joecar's Avatar
Did you program that into V1...?
It shows zero channels... try clearing and reprogramming it.
Old 04-09-2013, 01:26 AM
joecar's Avatar
outkast,
can you start a thread on the EFILive forum (in the V1 section) and post those images...
I'll dig out my V1 and compare it to what you see.
Quick Reply: efi live v1 trouble
