Bad IAC??
Bad IAC??
Recently my car has been idling high and surging when in gear, especially coming to a stop itll be around 1500 rpm with my foot on the brakes. Ill be completely stopped for a few seconds and the rpms will drop to normal then fluctuate up and down. I have been reading IAC counts on my scan gauge and ill see anywhere from 0-50 or so when im stopped. If the car is in park and I let it idle, itll surge a little bit as well. I unplugged the IAC when the car was running and and it ran normal at idle parked but if I do it before I start the car the rpms will shoot up to 2500. I checked for any vacuum leaks and couldnt find any, but Ill look again.
Iv also done a tps and iac relearn and it didnt change anything. I just put on a ported stock tb from Potz (ebay) and it seems worse than when i had the stock throttle body on. would this make a difference?
Any thoughts on if this is a bad IAC or something else?
So I thought I fixed it and its still happening. I swapped iac/tps and it was running fine for a little while then it happened again. I found a cracked pcv hose (from tb to valve cover) and replaced it. I disconnected the battery after doing so and it drove fine for 10-15 minutes then the next time I went to drive the car it started acting up again.
I bought a stock tb that will he here sometime this week and ill give that a try.
