Holley dominator wiring
Old 04-04-2013, 11:33 AM
V666's Avatar
Default Holley dominator wiring
I searched here and didnt see an answer here...forgive me if I missed it. Im running a LQ4 motor.There is no plug for the alternator in my holley main harness. Is there a loose wire that hooks to the alternator. I didnt see anything in the holley wiring diagram either?
Old 04-04-2013, 11:48 AM
LS1PUNK's Avatar
Negative, there is no connector on the harness as the ECU can not control the alternator.
You have two options, wire in a resistor and connect the alternator to a 12v keyed source.
or
Purchase a one wire alternator.
http://powerbastards.com/products.as...=20&navsid2=29
with
http://powerbastards.com/cart.asp?rp...3D190%26pg%3D2
Old 04-04-2013, 02:00 PM
V666's Avatar
ok did not no that. I thought my truck alt was 1 wire ill look. So just hook up a keyed 12v hot with what type resistor?
Thanks for the help so far
Old 04-04-2013, 09:44 PM
LS1PUNK's Avatar
I cant remember exactly what resistor to run in line off the top of my head.
I just ordered a alternator and the Self Exciting Regulator Option Product ID: SEREG.
IMO using a resistor is a bandaid fix, yes it has worked for others and is cheaper but I personally don't like the idea.
Old 04-05-2013, 09:16 AM
V666's Avatar
gotcha thanks for the info.
Old 04-11-2013, 12:54 AM
gnx7's Avatar
I had the same issue. Fbody alternator with a resistor put in place to a switched power source did the trick.
Quick Reply: Holley dominator wiring
