new fix for PO102 (Low maf frequency)
I had previously posted my chronic issue with the PO102 and none of the following known fixes worked.
Replacing maf
vaccum leaks
Engine sensor fuse blown
fuel restriction
pcm faulty
We test the voltage to maf and it was correct at 4.9V. However here is where we were tripped up. The code was being thrown intermittantly during driving which suggests a wire or CONNECTION being loose. It was the freaking connection at the maf, power to be specific. Im talking about the little metal piece in the connector on the maf not the harness connector. We just straightened out and now the maf g/s actually increase with rpm now.
guess who
Replacing maf
vaccum leaks
fuel restriction
pcm faulty
guess who
Replacing maf
vaccum leaks
fuel restriction
pcm faulty
guess who
Replacing maf
vaccum leaks
fuel restriction
pcm faulty
guess who
