Tune on stock 05 CTS-V w/Dyno numbers
Hey guys, I'm not on here pounding away at the keyboard much because I do it enough at work then when I'm playing around with my hobby, tuning LSx's.
With that being said, I wanted to give a short background of this car and the tune.
2005 CTS-V rebuilder... (trying to get it finished if I could just stay out of it), bought it right, damn near stole it actually. This car is 99% stock but only because one of the cats was rattling so I had them cut off. Other than that... Bone Stock.
I have been tuning it on the street pretty much between work and the house, just dialing in the VE, MAF and timing to what I thought was optimal on the old Butt Dyno and using the AEM Wide band that I stuffed down in my ash tray. I have my VE and MAF Cal really tight now and I could not believe how far it was on the lean side from the factory, upwards of 12% out actually. There is so much power to be made just dialing in the very generic tunes that these things come with from the factory.
The first picture is pretty self explanatory, shows my new baby on the Dyno at Humble Performance in Tulsa Oklahoma.
My first Dyno pull was on the stock tune. Peaking at 326 hp and 321 tq. I was hoping that it was going to make more than that but its the cards I was delt so, whatch gonna do.... Tune it of course. After the first pull, I put what I call my street tune in it and the graph below shows the gains.
17.37hp peak gain
12.09tq peak gain
Next I starting tuning it on the dyno. With the heat soak, I was barely able to get much over 24* of timing due to KR which I don't see on the street. The rest of my pulls are dyno queen tunes but I know it will make more on the street because it runs 28* with no KR. After Lowering the AFR from 13.0 to 12.8 I was able to make a considerable amount more power which the next two graphs show. The first one showing the difference between my street tune and final tune and the second one is compared against the stock tune. Enjoy..
Total Peak Gains from stock.
26.77 HP
26.42 Tq
17.37hp peak gain
12.09tq peak gain
26.77 HP
26.42 Tq
9-Second Club
Where are your air/fuel numbers?
That would be a clue to the big gains. Some of those cars go into COT mode on a dyno pull. Big gains stopping that. Also aftermarket "cold air kits" screw up the fuel trims so on the first pull it will be adding 10% or more fuel to an already over-rich car. Big gains fixing those two problems. Cars with that engine and neither issue won't pick up that much. If the car owner is watching, and you don't explain that to them you look like a real hero. LOL
Good job fixing that one.
Good to hear from you agian ED, havent seen you since you tuned my 96 Impala and gave me all the pointers on the build and told me where to get my intake and heads done at. Then you turned around, dyno tuned it for me all day and didn't charge me a damn dime. Leaving me with a Monster Sled and and extra $500+ in my pocket. Don't run across that every day but I never forgot it. I still owe you so... Hit me up anytime if you need any advise on tuning, lol. That was a joke.
Actually a friend of mine bought your old dyno so... if I can get him off his *** and put it in, then I wouldn't have to hop around from shop to shop to get in a dyno.
Steve
