Am I screwed!?
Old 06-04-2013, 04:31 PM
shamarie's Avatar
Exclamation Am I screwed!?
I got these codes off my 1998 z28 ls-1 Camaro
does this mean I'm screwed?
PO305
PO401
PO442
What the heck am I gonna tell my husband? and how in the world did this happen?
any help would be greatly appreciated
Old 06-04-2013, 05:38 PM
sreve's Avatar
P0305 = cylinder miss #5
P0401 = EGR low flow
P0442 = EVAP small leak
I'm sure he will be understanding cook him a nice dinner
and give him a massage.
Old 06-04-2013, 05:56 PM
2xLS1's Avatar
PO305
PO401
PO442
You should probably just pack your things and leave now.
But be sure and make him a pie before you leave.
Old 06-04-2013, 06:30 PM
grimspyder's Avatar
Old 06-04-2013, 07:13 PM
NorcalDiablo's Avatar
What is the story behind this? when did the codes start? Just today? What happenend or changed?
The 401 and 402 should be really easy fixes.
Old 06-04-2013, 07:28 PM
porkenstein's Avatar
Without getting too crude the answer to keep you from not getting in trouble is actually in your original question.
Old 06-04-2013, 09:36 PM
shamarie's Avatar
Unhappy Ha good one!
COME ON you guys..
those replies were kinda funny.. but yeah, anyway..
the ses light has been on for a few months, husband said no big deal he knows what its on for.I just took his word for it. He does like to rag on it a bit and has gone from 5th to 4th a few times on accident, still makes me cringe though, anyway.. last night driving home I heard a very very faint clinq sound as I was coasting at about 65 mph. bout 5 to 10 min later ses light starts flashing engine gets sluggish, oil pressure goes to the middle line and below. I pulled in a parking lot checked the oil about 20 times it was at the "add" level, it was caramel colored. Also it had somewhat of a ticking sound. I put oil in it and it sounded a little better, I drove it across the parking lot the ses didn't flash and the engine felt a little better the ticking was kinda gone but I wasn't confident enough to drive it home. also when I checked the oil there was a tiny bubble. I've heard that bubbles in the oil is not good .So this morning I got the obd2 diagnostic thing, and that's how the codes came about.the ses light flashed only when I got over 30 mph also when I drove it home it backfired, and did the popping thing, it has a Borla exhaust? and has been hooked up to a Diablo tuner if that helps any. Please excuse my lack of car knowledge. I'm almost certain though this is a bad bad thing, and I know my Husband is gonna throw a rod when I have to tell him. (No pun intented) I'm just trying to gather all the knowledge I can before I give him the bad news. I appreciate the help.
Old 06-04-2013, 10:11 PM
LSX Power Tuning's Avatar
Blinking check engine light is from a miss-fire (P0305) I would the simple things first like the plug wire didn't come off or break, check the plug, and then coil.
Old 06-05-2013, 06:23 AM
flattusmaximus78's Avatar
Pretend it didn't happen. Let him turn it on, and let it happen to him. Problem solved lol.
Old 06-05-2013, 10:17 AM
SSellers's Avatar
I can't believe no one asked what in the hell a woman was doing driving a car. If it was an emergency trip to the grocery store I understand.
Couldn't resist.
Old 06-06-2013, 11:21 PM
bwy23's Avatar
Check # 5 cylinder....anything that will make THAT cylinder not contribute....wire, coil, plug. If wire is not off or broken...easiest thing to do is switch the #5 coil with another and see if the misfire follows....if so walla the coil is bad. Worst case is a mechanical condition affecting that cylinder...low compression etc. Good luck!
Old 06-07-2013, 11:50 PM
ls1 1990 VN's Avatar
Tell him, Honey my engines broken, think I need a stroker.
Old 06-08-2013, 01:55 AM
AgFormula02's Avatar
Broken valve spring
Quick Reply: Am I screwed!?
