PCM Wiring Harness
PCM Wiring Harness
2001 Camaro SS. The blue bank on my PCM/wiring harness got water in it and corroded the pins/pin sockets on both the PCM and harness. I have replaced the PCM but am looking for the blue side of the harness. Does anyone have an old PCM harness lying around? Is there a better solution than splicing in a harness?
You can just replace the entire blue connector. Current Performance sells the raw connector for $39.50 and anyone good with a crimper or soldering iron could do this job.
Awesome! Thanks for the feedback. I like the raw connector idea. I do electrical/electronics work and have crimpers and soldering equipment at work. Thanks, again.
