AEM Wideband to HPtuners
Old 06-13-2013, 07:51 PM
Monte4ever's Avatar
Default AEM Wideband to HPtuners
I am attempting to hookup my AEM UEGO wideband to HPtuners. I see that the white wire from the wideband goes to pin 1 and the black/ground wire goes to pin 5 on HPT's green connector. Is there anything else I need to worry about? I've read that I have to input the voltage offset (or something like that). What does that involve. Thank you.
Old 06-15-2013, 09:06 AM
DMM
DMM's Avatar
You have the physical connections right, and you have to set the slope. Do you plan on using this for AFR or Lambda?
I have a a confg file that you can use that is set up for Lambda error, which makes it easy b/c all you have to do is multiply the existing values by the number in the histogram. Don't have my laptop on me at the moment though.
Old 06-16-2013, 06:11 PM
Monte4ever's Avatar
Thanks for the reply. I decided to use the EGR PID to log my AFR through.
Quick Reply: AEM Wideband to HPtuners
