Ls4 & 0411
Old 07-06-2013, 02:47 PM
Scott68B's Avatar
Default Ls4 & 0411
I'm going to be using a 0411 PCM on an LS4. I'd like to keep the LS4 cam sensor in place if possible. The sensor location is 180 degrees opposite to a "normal" LSX motor. What issues will I be facing with this setup? Will a wiring change be needed? I've got an 06 motor with the 24 tooth crank sensor.
Thanks for any insight you can give.
Scott
Quick Reply: Ls4 & 0411
