First to Market: 2014 GM Gas truck tunes!
DiabloSport Inc is pleased to announce that we have released support for the new 2014 GM gas trucks on our inTune I-1000 device.
Tunes for Premium fuel and 87 octane are provided. Gains on premium fuel are about 16 rwhp and 20 ft/lbs, gains on 87 were about 8 rwhp and 15 ft/lbs.
There is also a tune for mileage called MPG booster, which optimizes DoD settings for highway driving.
The inTune also offers the most end user adjustable parameters of any handheld programmer, engine params include:
Axle Ratio
Change tire size
COT ON/OFF
COT time delay
DoD ON/OFF
Idle drive
Idle park/neutral
Rev limit in Gear
Speed Limit On/Off
WOT fuel 2k-3.8k
WOT fuel 4k-4.9k
WOT fuel 5k-7k
WOT spark 1k-3.8k
WOT spark 4k-5k
WOT spark 5.2k-7k
TCM support is also available, and our Firm or Hard shift options are there as well. In addition to the preloaded TCM tunes, again, you have tons of adjustable parameters available to you:
1>2 Normal RPM Shift
2>3 Normal RPM Shift
3>4 Normal RPM Shift
4>5 Normal RPM Shift
5>6 Normal RPM Shift
1>2 Sport/Tow RPM Shift
2>3 Sport/Tow RPM Shift
3>4 Sport/Tow RPM Shift
4>5 Sport/Tow RPM Shift
5>6 Sport/Tow RPM Shift
1>2 Part Throttle Shift Pressure Normal
2>3 Part Throttle Shift Pressure Normal
3>4 Part Throttle Shift Pressure Normal
4>5 Part Throttle Shift Pressure Normal
5>6 Part Throttle Shift Pressure Normal
1>2 WOT Shift Pressure Normal
2>3 WOT Shift Pressure Normal
3>4 WOT Shift Pressure Normal
4>5 WOT Shift Pressure Normal
5>6 WOT Shift Pressure Normal
1>2 Part Throttle Shift Pressure Sport/Tow
2>3 Part Throttle Shift Pressure Sport/Tow
3>4 Part Throttle Shift Pressure Sport/Tow
4>5 Part Throttle Shift Pressure Sport/Tow
5>6 Part Throttle Shift Pressure Sport/Tow
1>2 WOT Shift Pressure Sport/Tow
2>3 WOT Shift Pressure Sport/Tow
3>4 WOT Shift Pressure Sport/Tow
4>5 WOT Shift Pressure Sport/Tow
5>6 WOT Shift Pressure Sport/Tow
Upshift Torque Management ON/OFF
An update to add support for these applications to the Trinity T-1000 monitor device will be coming soon!
Thanks
Axle Ratio
Change tire size
COT ON/OFF
COT time delay
DoD ON/OFF
Idle drive
Idle park/neutral
Rev limit in Gear
Speed Limit On/Off
WOT fuel 2k-3.8k
WOT fuel 4k-4.9k
WOT fuel 5k-7k
WOT spark 1k-3.8k
WOT spark 4k-5k
WOT spark 5.2k-7k
Thanks
