MAF sensor problem ! Help please
Hi
My car is camaro ss 2000 m6 stroker 418 cid i have problem with MAF i changed it also i changed the fuse because it was blown ! After that i took the car to the tuner and he said that still there is problem in the MAF sensor i explan for him i was change it with new one !! Then we checked the harness with electrical and every thing are ok !!!! Then tuner said to me maybe there is problem iin the ECU and i should to change it !!!!!!!! Is that right ?? In fact i have problem with my alternator maybe because the voltage gague in the dash read 8 below 13 i thoght too much low !!! I told him maybe this is the reason he said no !! So can u tell me what i can do ??
Moderator
Low system voltage messes up a lot of things and is
something you should get right.
The rest of the problem description doesn't tell me
much. Problem, problem, but -what- problem? Not
putting out a signal, not liking what it says, ???
Ok
He said that every thing are good and the harness also good !!
But my ECU give symptom for the tuner ?
And no one know what is the reason !!!
Update
i changed the ECU and alternator . Still i have problem (( ??
Update
