Can I use a 2002 silverado computer in my 2002 z28?
Yes you can.
You only need to do a full flash with your stock tune file, or download one from a repository.
Using the stock tune from the damaged PCM assures full compatibility and only needs 1 license.
Just be careful not to use the last file you flashed when the PCM was bricked, if some parameter is corrupted or out of range you will also brick the spare
The software nowadays is pretty good, it usually won't let you enter values that are out of range of tables/constants.
Speedometer parameters too small will brick the PCM. A bricked PCM can be repaired with special equipment.
I have seen people who bricked a few PCMs using bad or corrupted files
