mas air fuel translaters
They are about $200 and they are a cinch to use. Simply turn 2 *****. One for low RPM operation, the other for WOT operation.
You will need to monitor your LTerms (scantool) to dial in your lower RPM running properly, and you will need a wideband O2 to properly dial in your WOT running.
Good Luck
Good Luck
