Scanner disconnect?
Scanner disconnect?
I was data logging lastnight, and about 370 frames into it, my scanner would disconnect, and would not reconnect unless the car was turned off, and in the run position.
I tried the scanner on another car, and no issues, so I am sure its the wiring..
anyone had this issue?
I am going to check the wires and data wire to the PCM, just wanted to see if anyone ever had a similar issue and found the cause.. I searched this on here and HPT without finding the cause..
Does anyone know WHERE the grounds for the obd2 connector are located on the harness??
The ground on pin 4 of the DLC goes to the left I/P mounting stud behind the kick panel. The ground on pin 5 goes to the rear of the driver-side cylinder head. As for the data line on pin 2, there is a splice pack for the common data connection of the various module's data lines. It is attached to a bracket above the DLC, near the turn signal flasher.
Did the scanner remain powered or did it go dead? If dead, that may indicate a loss of power from the cigar lighter circuit to pin 16 of the DLC.
I will track down the grounds.. the scanner has power, and just disconnects after being open for long enough to get 300-400 frames.. then will not re connect.. I think its a ground, I will check them all..
thanks.
thanks.
