SES Light: P0171
SES Light: P0171
My friend has a 2000 A4 Z28, and his SES came on so he got it scanned, and came up with P0171 System Too Lean (Bank 1)
The car is mostly stock except for a lid and a loudmouth.
Any ideas what would cause this?
-Matt
-Matt
Being it is saying ONLY left side is lean,
look for a bad injector, disonnected wires to a injector, AIR check valve sticking open or the car is running so lean but left side is leaner then right and has hit the max LTFT allowed for that side.
-Matt
-Matt
yeh this is where efilive,autotap,vcm scanner do indeed come in handy.
being able to watch from a dead cold startup shows you a bit. I do have a lazy heater element, (bank 1) on a 60F morning will take about 30 seconds longer to read the same as B2, but after a minute or so both are reading the same PEAK and Trough MVolt #'s so i'm not sweating it.
Go find someone with a scan tool and check for things like cylinder balance test, misfire counts, etc. makes the guesswork That much easier.
