Nitrous Tuner near Fort Wayne, IN
Old 08-29-2013, 12:03 PM
SS1875's Avatar
Default Nitrous Tuner near Fort Wayne, IN
As stated, looking for a good nitrous tuner near Fort Wayne IN. Anyone have a suggestion of who to trust?
Old 08-29-2013, 12:39 PM
87silverbullet's Avatar
Like I stated in the nitrous section, yourself and the nitrous section.
Old 08-29-2013, 06:35 PM
SS1875's Avatar
Thanks for the response, unfortunately I must rely on someone else with the proper equipment to actually do it. As far as reading the plugs and such, I have plenty of help in that area however it's nice to know there are others that can lend their knowledge as well.
Old 08-30-2013, 08:31 AM
You run a pass at the track and read your plugs, no equipment needed. What equipment are you talking about?
Old 08-30-2013, 11:45 AM
boostit5.3's Avatar
5/8 socket a short extension and a rachet?
Old 08-30-2013, 12:17 PM
^^^I was going to post that but I didn't want to come off as a smartass.
Old 08-30-2013, 02:46 PM
boostit5.3's Avatar
i do think this guy maybe needs to learn some basics first?? i would recommend putting a wideband in it if you havent already... i like being able to watch what the car is doing in between tune ups on spray so if something goes south i might get a chance to catch it. all you have to do is make a wot pass to redline then shut down immediately... try and get as little idle time as you can, then pull a plug out and post some pics on here in the nitrous section. people will usually help you out its fairly easy to do most nitrous kits come jetted rich so you shouldnt blow anything up as long as your fuel pump is up to the task and you pull some timing.
Old 08-30-2013, 02:47 PM
boostit5.3's Avatar
and put some br7ef plugs in it spray that hoe
Old 08-30-2013, 02:49 PM
boostit5.3's Avatar
are you worried about the 6 speed?? you can wire in a bunch of other boxes but my buddy is spraying a 200 on his stock 2002 ws6 6 speed with nothing but a wot switch, just dont spray under 3k rpms and your fine.
Quick Reply: Nitrous Tuner near Fort Wayne, IN
