Microsquirt issues..
Old 09-02-2013, 01:06 PM
superbean's Avatar
Default Microsquirt issues..
I just put together a 5.3 turbo on microsquirt and I'm having an issue with it running. It will fire up and idle (2000rpm) but every 5 seconds or so it has a flat spot in the duty cycle and it drops to 0 for a split second then it goes back up to normal, then again.
Any ideas where to start to track down why I would have an intermitten signal issue with injectors?
Old 09-02-2013, 02:28 PM
aknovaman's Avatar
Monitor battery voltage and see if it is jumping around. If so its likely a loose ground. Also use the tooth logger to verify solid crank position sensor output. O'reiley crank POSN sensors are prone to intermittent failures.
Old 09-02-2013, 02:52 PM
superbean's Avatar
looking into that now. Also, do all sensors need to be physically grounded? I'm only getting continuity to ground from the two pins (grounds) for the microsquirt
Old 09-02-2013, 03:41 PM
aknovaman's Avatar
Wink
Make sure sensors are grounded as shown here. Crank posn can be grounded to main Micro ground. I don't recommend sing the sensor GND for it.
http://www.useasydocs.com/details/ew3_hires.gif
Old 09-02-2013, 06:07 PM
superbean's Avatar
Ok i've redone the sensor ground (it had a bad cold solder connection). I am not sure if the Crank sensor ground is separate or if it its used in the sensor ground. Why do you recommend not using it in the sensor ground?
Old 09-02-2013, 06:09 PM
superbean's Avatar
IT's not having any drops in pulse width now that I can see.. idles better but still bounces between 1400 - 800 rpm
Old 09-02-2013, 07:23 PM
aknovaman's Avatar
Call me.
Chk your pm for my phone number
Old 09-03-2013, 07:45 AM
superbean's Avatar
Got it, i'll buzz you this afternoon after class/work
Quick Reply: Microsquirt issues..
