ECM/TCM fuse
Old 09-12-2013, 08:38 PM
GFallen's Avatar
Default ECM/TCM fuse
Hello, my issue is under higher RPM with fast 1st-2nd gear shifts I keep blowing my ECM/TCM fuse. It started at the drag strip on my last of four runs and has continued. No codes, the car just shuts down and the speedo and tach "Freeze". I've went over wires top and bottom and nothing looks out of place. Any suggestions? Mods are in sig. 07 CTS-V
Old 09-13-2013, 05:38 PM
joecar's Avatar
Sounds like your 1-2 shift solenoid has an internal short... measure the resistance across its terminals.
Old 09-14-2013, 08:29 AM
GFallen's Avatar
Thanks for the reply. I'm new to this so can you tell me exactly where to locate the shifter solenoid.
Old 09-14-2013, 05:47 PM
joecar's Avatar
It is accessed by removing the transmission pan.
Quick Reply: ECM/TCM fuse
