Car dies, with time starts again....help please!
im having a issue with my car keep stalling after awhile. its a 99 z28, I just did a header and cam swap, and now I have this issue of the car just dying on me after a few minutes of driving. Im thinking its heat related because after I let the car sit for a few minutes, sometimes 10-15 minutes, the car fires right up and drive good for a few minutes then dies again. battery voltage is low while cranking, but doesn't slow down the cranking at all. and while driving the gauge shows 13 volts and the ect is not high. I have not got a tune yet, the car wont even make it 5 miles without dying...its a small 220 cam. I have heard that the icm can be intermittent when it gets hot, but where is the icm on a ls1 Camaro? I didn't know it had one. the engine bay gets pretty hot since I have a Sunoco hood that doesn't let heat escape very good. im stumped and would really like some help please. here are my files to show how it happends. its around 3:50.
yea I did a header swap and I haven't deleted the rear o2s yet. also the iat is mounted in the lid housing, and since im in phoenix my IATs get pretty hot. they used to get up to 155'F but I changed the intake to the slp flow pac. it dropped temps by over 40degrees.
also, can the alternator output affect the coils? is there a certain voltage that will stop power to the coils? I noticed my connection to my alternator is soaked in power steering fluid...
im gonna get a tune as soon I can get the car to drive for more than 5 miles without shutting off. its staying in open loop for now and that's fine, I have been monitoring the pids and everything looks good. I just don't want to take it to get a tune, and on the dyno the car cuts off and me and the tuner have to wait till the car turns back on just to tune the car. once I get this issue fixed I will tackle the other issues in order of priority, because I know they are also important issues. its just that right now this car is my wifes daily and I don't want her dealing with is. I appreciate your help though
edit : its staying in open loop. misprint...
I agree it does and maybe im wrong but if the car stays in open loop doesn't that mean it goes full fuel? I don't think that would cause a no start issue, or dying while driving. going into closed loop is emissions related. the only codes I have is for the O2s and the egr. thank you, I really hope to get this sorted out
