What is the max possible timing for stock pcm?
Old 05-03-2004, 09:35 PM
LOnSLO's Avatar
Default What is the max possible timing for stock pcm?
Curious if it will go up to 60 degrees or so. Running an experiment very soon
Old 05-03-2004, 09:44 PM
ISPEEDWS6's Avatar
Most I've ever had so far has been 45, but swing by i'll throw 60 degrees in your car and you can go around the block(if it'll make it) and we'll see what it does...besides spark knock like a beotch.
Old 05-03-2004, 10:06 PM
LOnSLO's Avatar
I just need to know what the max values are for the cells in edit. Like above, this will be a fueling experiment
Old 05-03-2004, 10:15 PM
Bink's Avatar
99.9 max for High Oct table. 100 rolled to 0.00. FWIW.
Old 05-03-2004, 10:21 PM
LOnSLO's Avatar
Thanks. That's what I needed. Don't have my edit here right now to play with.
