HP Tuners and timing
Old 09-30-2013, 10:12 AM
C5AJ's Avatar
Default HP Tuners and timing
What should HP tuners show on the scanner display for a stock engine at idle, and at various RPM?
Does this figure shown on the scanner indicate base timing, or overall with advance?
Old 09-30-2013, 11:29 PM
8 Second Truck Club
Blown06's Avatar
There is no mechanical or vacuum advance without a distributor. The figure on the scanner is the actual timing.
Old 10-01-2013, 02:42 PM
C5AJ's Avatar
Does 18* @idle to a max of 40* @ RPM sound about right, sounds a bit high to me?
Old 10-01-2013, 09:24 PM
MontecarloDrag's Avatar
Idle timing for a stock LS1 with unmodified tune goes from 8° to 28° max
There are a few adders that can add up to 7°
It is uncommon to see more than 25° for a healthy engine. Post a datalog to see what is happening
Old 10-01-2013, 11:33 PM
danieloneil01's Avatar
around 18* idle. To see a stock LS1 file go to hptuners and download one.
Old 10-02-2013, 12:52 PM
C5AJ's Avatar
O.k. I will get a log. In your guys' opinion, would this much advance cause this?
Old 10-02-2013, 07:43 PM
Cause what?
Quick Reply: HP Tuners and timing
