ABS, brake and TCS light...code c0090
Old 10-02-2013, 10:05 PM
User_name's Avatar
Default ABS, brake and TCS light...code c0090
Ive got a code for C0090 RR ABS Solenoid #1 Circuit Malfunction. Cleared codes and this comes back as active with all 3 lights. Vehicle has a 9" with the 4 channel abs/reluctor rings. Could this be a problem with the right rear wheel speed sensor and or wiring? Or could this just be a problem with the ABS block? I was thinking of checking wiring at the sensor for voltage/resistance. I did not see any corrosion on the connector. Im just trying to figure out where to start diagnosing this problem. Thanks
Old 10-03-2013, 05:46 AM
sreve's Avatar
See the trouble shooting tree.
File Type: pdf
Old 10-03-2013, 11:13 AM
User_name's Avatar
Yea I checked that out on alldata but instead of just replacing the EBCM I was wondering if there was anything else I could check before doing so. Or if anyone else has experienced this. But thank you
Old 10-03-2013, 11:55 AM
User_name's Avatar
I did search for a bit and found that the cause usually is a faulty EBCM but I have not seen this code on here yet so I figured I should ask before trying to find one off of a 2000 4 channel TCS equipped vehicle. Any other ideas, or just EBCM replacement?
Quick Reply: ABS, brake and TCS light...code c0090
