HPTuners 2bar GTO map sensor issues
Old 10-09-2013, 11:41 PM
drpepper601's Avatar
Default HPTuners 2bar GTO map sensor issues
I am having some issues with my new cobalt map sensor (PN 12615136 or so the ebay ad stated). I am now running a 2bar sd tune with no maf installed on the vehicle. I tried the settings for linear/offset at 207.66 / 9.00. The scanner reads 104kpa and the car does not run properly.
When I set the linear/offset to the stock 1 bar sensor values, the car starts up and the scanner reads the MAP values appropriately.
Either way it does not read over 104kpa
Did I get screwed and receive a 1 bar map sensor?!
The file needs to be renamed to .hpt
Quick Reply: HPTuners 2bar GTO map sensor issues
