LS Atomic EFI
its no different than what a stock pcm does....
the difference is that it uses a wideband all the time...and its been massaged a little to fit more of what is in your car by changing a few parameters on the handheld programmer.
nobody makes a Fully self tuning device.....its made for you to set a few parameters, and it will learn fueling...you still have to do the rest
you wont get the max out of it unless you have some basic tuning knowledge and a dyno.
it is setup to be pretty conservative and safe for fueling and timing on a wide variety of setups straight out of the box.
