Brand new to HP Tuners, now... about the tune repository
So my question is, when I download a tune from the tune repository, is there a simply way to apply all of the changes someone made to their tune (that is uploaded to the repository) to my cars tune? I downloaded my VCM info and I can see changes between the two .bin files, but before I spend a ton of time finger picking in each difference between the two, I just want to see if there's a simple way to "copy over" all of the inputs from the downloaded bin to my bin from my car. Or, have I just been welcomed into the tuning world and all the hours it consists of?
OR, do I just need to cough up the additional two credits to unlock the tune I've downloaded from the tune repository, and use it that way? Obviously, I'd like to avoid this if I can. Thanks for everyone's help!!
thats your answer in bold.
if not, have fun copy and pasting all the differences
You can copy all the changes to your tune with a few clicks.
Open your tune
Open the downloaded tune in the compare menu
Then go to the menu - compare - View comparison Log
A window with all the differences will show. If you want to copy everything, right click on Engine and select Copy over differences. It will copy all engine parameters from the downloaded tune to yours.
Then do the same for transmission, speedometer, etc.
That's all
Open your tune
That's all
It's pretty easy to copy paste bits. Be careful with the repositary tunes, there's some crap ones in there. Desensitised knock sensors, too much timing, dog's breakfast VE tables, even saw one with more timing in the low octane table than in the high. If you don't know what a table does and how it should be set, leave it stock and read up! You're right about the "lots of hours" part, but it's good fun.
LS1TECH Sponsor
shouldn't take more than 20 seconds to copy over an entire tune to another sans dtc's as previously noted.
Keep in mind there are some tables that if altered blindly can fry the pcm so be mindful of changes you are unknowingly copying over from one tune to another ie etc tables, some speedo tables, etc.
