wierd misfire thats driving me bananas
Whats up guys as the topic says wierd misfire , cars a 2000 z28 lq9 418ci stroker tuned speed density , after car has reached operating temp its got a wicked miss under load and wont turn past 3k ive check tps, coolant temp sensor , map sensor and wireing , checked fuel pressure and has new fuel filter on it , I also checked all the ground and everything is good and so is the voltage any insight would be greatly appreciated
Thanks, Jose
Thanks, Jose
Sorry for the late response , just put a fresh set of plugs and taylor wires , still has the miss but it only does it once its been at operating temp for a while I thought it might have been the f.p but its got 60psi rite befor it fonally dies
can you watch a misfire counter in data?
If not, find someone with a scope and take a spark signature sample when it's cold and running well, then do it again when it's warm and not running well. Compare the 2 and go from there.
Thanks for all the help guys really appreciate it and sorry for the late response been super busy , figured out what it was , the extension for the map sensor wires were very brittle and done with butt connector thanks to a good shop so I was a bit pissed , well ran new wireing and soldered and heat shrinked everything , looks better then factory lol
Thanks again guys
Thanks again guys
