1999 Camaro
1999 Camaro
Hello. I am trying to finish up my LS1 swap in my 65 Chevy II and I have two wires that I am not sure what to do with.
1. Red conn., #53, spark retard signal
2. Blue conn.,# 8, TPS 5v reference
What should I do with them? Thanks
is the pcm from a 99 Camaro??
if so
red con. #53 not needed
blue con.#8 is the 5v ref for throttle position sensor this is needed the pcm monitors this and should be ran to the plug
if using truck pcm 99-02
tps plug to pcm
A-gry c1 blue\#46 5v ref
B-blk c1 blue\#54 sensor ground
C-drk blu c2 red\#24 sensor signal
if so
tps plug to pcm
