HPT boost log?
Old 01-03-2014, 06:37 PM
1bad03snake's Avatar
Default HPT boost log?
I have tried to config a boost log off the Map and its not reading. Anyone have some advice for this?
Thanks for your help
Matt
Old 01-04-2014, 08:28 AM
MMWS6's Avatar
Forum wont let me upload a file here... PM me your contact info and Ill shoot you a .cfg file to compare to what you have so far
Old 01-08-2014, 01:08 PM
Double A's Avatar
While your at it mind sending me the same? Sent you a PM
Old 01-08-2014, 01:23 PM
Moderator
jimmyblue's Avatar
Are you using the -right- MAP? Custom OSes have
their own scaled MAP PID and the standard ones
aren't right anymore; hopefully you're not trying
to log boost levels on a 1-bar MAP sensor.
Old 01-10-2014, 08:29 AM
MMWS6's Avatar
Sent a .cfg file and a log. The one I sent is of an LS2, 4" bore and stroke, boosted, SD tune and 60lb injectors in that one. Tune is scaled for the injectors, they are 73lb at 4bar
Old 01-10-2014, 03:47 PM
Double A's Avatar
Thanks for the great info and your assistance!!!
Much appreciated
Old 01-12-2014, 07:45 AM
MMWS6's Avatar
No problem. I wanted you to have the car info because when you would view the log, it would probably look kinda wonky....lol Every table in the tune, and I mean EVERY TABLE, has been scaled that referenced g/cyl or lb/hr in it. I spent two weeks on that tune and is 100% SD. Now we are installing a 100mm intake and "card style" MAF to finish it off. In Australia, where the truck is, they have to have a MAF on their vehicles to pass inspection. Once we get the MAF in place and it's tuned, let me know if you need any info from that to help you out. Also, on the HP Forum, I'm sure you can find the same info but I know my .cfg file is good and has what you need to tune an LS2 properly. Just so you know as well, that is an E40 ECM... hardest dam PCM I've ever tuned, that thing is a bitch!
Quick Reply: HPT boost log?
