car will not run with MAF unplugged.
Old 02-01-2014, 05:14 PM
smit2732's Avatar
Default car will not run with MAF unplugged.
I'm helping a friend tune his VE table but the car will not run with the MAF unplugged. Is this simply because the VE table is so far off or am I overlooking something? It will barely idle and the LTFT's are at around 20-25 at idle. Its a 2001 LS1 using HPtuners.
Its been awhile since I have done any tuning but I dont remember having this problem in SD mode.
any suggestions
Old 02-01-2014, 10:51 PM
joecar's Avatar
Does it throw a MAF DTC...?
If it does then the VE table is wrong.
If it does not then it is still trying to use the MAF.
Old 02-01-2014, 10:58 PM
LSX Power Tuning's Avatar
Email me your tune and I'll look at it and see if you over looked anything. Email is in sig below.
Old 02-02-2014, 04:52 PM
smit2732's Avatar
I will send it to you tomorrow. Thanks!!
Old 02-05-2014, 12:57 PM
redtan's Avatar
VE is way off if you get LTFTs that high. Tune that better and it will run without the MAF as long as it's throwing the MAF codes.
Old 02-05-2014, 01:32 PM
danieloneil01's Avatar
Is the MAF 5 or 3 wire? If 5 the IAT is built into the MAF and would explain why. If it's that far off multiply the entire VE table by 20%????? It's what I would do then I would tune part throttle and see where my upper tables would be at but I'd have it a bit richer before going ***** out WOT tuning.
You can force SD without unplugging the MAF, right?
Old 02-05-2014, 04:17 PM
redtan's Avatar
Yup, just fail it in the tune itself and bye bye MAF.
Old 02-05-2014, 04:48 PM
joecar's Avatar
A MAF DTC has to show up.
Old 02-05-2014, 05:55 PM
smit2732's Avatar
it has a seperate IAT, doesnt throw a MAF code but I'm pretty sure the SES send is turned off. I will double check though. Thanks for the replies!!
Old 02-05-2014, 08:41 PM
Moderator
jimmyblue's Avatar
High trims can also be from false trimming and they
can compound a rich error (like, say, a low end of VE
table that still looks stock while he tossed a lumpy-
*** narrow separation cam in there). MAF is not as
easily fooled and may be contributing to not-totally-
bogus airflow readings when in the picture.
Old 02-06-2014, 12:59 PM
I know on my car I can't select 3 for the MAF codes as the car won't run so I have to use option 2.
Old 02-06-2014, 04:49 PM
joecar's Avatar
You have to check with a scantool that a MAF DTC shows up immediately at startup...
without the MAF DTC, the PCM is still attempting to use the MAF.
Old 02-07-2014, 10:27 PM
smit2732's Avatar
Thanks for the input guys. Hopefully I will have time to play with the tune over the next few weeks.
Old 02-08-2014, 12:23 PM
smit2732's Avatar
Thanks for the help guys!! I just looked at the tune and the MAF DTC's were set to option 3. I set them back to 1 and will try it again,
Old 02-08-2014, 01:33 PM
Set them to 2 not 1 and google, "hptuners VE tuning PDF" click first result.
Quick Reply: car will not run with MAF unplugged.
