Twin DBW conversion using GM ecu
I'm running a aftermarket ECU, and was wanting to run a DBW system.
My idea was to pick up a Gm PCM but just use it to drive the DBW only , then there are other boxes to split the signals to run twins . Yes I here you say why run a aftermarket ecu in the first place well it has Traction control that monitors all 4 wheels speeds launch control flat shift anti lag and slot of other options I wanted .
Has anyone done something similar ??
