silly wiring harness/electrical question
when i was hooking everything back up in the car the ground wire that comes out by the bank 1 (left side) harness by the O2 broke. i left it for now thinking all of my other grounds are good but now i go to start the car... nothing. can that tiny ground wire be causing my nightmares. i check i have fuel going to the rail but the car acts like it starving for gas cranking and cranking but wont start??? thanks
yea i know it comes out of the wiring harness right before the o2 but i cant seem to find out what it is or where to track it too. i need to find out what it is and where it runs in the harness. ive cut the loom a good couple feet back and cant find where it started. anyone with ideas?
thanks
thanks
You referred to it as a "ground" wire. Before it broke, to what did it connect? (on the end that is exposed).
It may be: (a) the wire that supplies power to the fuel injection coils on that bank (switched by the PCM); or (b) the wire that supplies ground to the fuel injection coil circuits.
i dont believe its an engine ground. i am in concur with your statement about it being a ground for the coil circuits. it came out of the wiring harness and bolted to the the body the problem is it broke off from the harness. the end is still bolted to the body i need to trace where it broke and put it back together
you guys can see where im confused from the picture it comes out of the wiring harness just a couple inches up from the o2 and me being in a hurry trying to move the wires around i pulled on it and pop that wire comes out of the harness never to be found again and what do you know about that time my car cranks but stops starting. crazy thing is i cut the harness open about a foot up and no trace of where it came from
Check the ground splice in the harness. You will see where all the grounds come together and come out as one wire.
http://lt1swap.com/removing_ground_from_splice.jpg
