ls1 swap wont idle
ls1 swap wont idle
I can't seem to get my ls1 to idle. It is a swap into an 89 Mustang. it will rev up if you hold throttle past 20%.
04 gto long block
01 camaro pcm wired to LT1swap.com diagram. no vats, no prndl switch, no egr, no rear o2 sensors. all deleted with hptuners. i pulled the factory tune out, shut all these off, and reinstalled the tune.
04 gto injectors, maf sensor, and throttle body
dynatech longtube headers, no cats
4l60e
All parts came from running cars
no mods other then headers. fuel pressure is good. no dtcs showing up.
04 gto long block
4l60e
You need a tune indeed and a different config. That one isnt showing nearly enough info. Looks like you are using the OG config. If you need some help, we are available.
