Trouble with LC1 wideband
Old 03-21-2014, 10:07 PM
1bdbrd's Avatar
Default Trouble with LC1 wideband
I installed my LC1 and Dynotune gauge today and tried to connect my laptop to it to change the the outputs. I don't have a serial port so I tried 3 different USB-serial adapters and none worked. I also tried those on 3 different computers. One was XP, one was Windows 7 and one was Windows 8. None of them were able to connect to the wideband at all. I tried a RadioShack adapter, a Dynex and a IOGear adapter as well.
Everything I found on Google said its a driver issue but all drivers were the most current and they were also installed correctly.
Any help?
Old 03-23-2014, 09:55 AM
1bdbrd's Avatar
Figured out the issue. I had the wrong 2.5mm plug for the terminator plug. Once I got a correctly made one, everything worked perfectly. Even on windows 8 with the IOgear adapter.
Old 03-23-2014, 11:49 AM
Iam Broke's Avatar
Glad you figured it out, I was going to suggest to check the comm port settings and slow the FIFO buffers down.
Quick Reply: Trouble with LC1 wideband
