E38 Revisions?
Old 03-24-2014, 12:30 PM
BADSZ28's Avatar
Default E38 Revisions?
Are there different revisions of E38s out there? I have a harness from an 08 Silverado that I need an ECM for. I know I need an E38 but research has shown there are different PNs for them out there. Does it matter? I want to be sure it will work with my harness.
Old 03-25-2014, 01:26 PM
BADSZ28's Avatar
Anyone have any idea? I cannot find the differences. I found two different service part numbers.
Old 04-01-2014, 10:05 AM
BADSZ28's Avatar
I would like to pick one up soon. But I want some feedback so I am not limiting myself if one is better than another for my application.
Old 04-01-2014, 11:57 AM
Iam Broke's Avatar
I don't have the info but perhaps if you post in the HPTuners forum for GM Gen 4 V-8's someone can help you out.
Old 04-01-2014, 12:37 PM
LSX Power Tuning's Avatar
E38's are not like the older ecm's where you can't flash them to anything you want. If you try to change the year or vehicle application they can easily be bricked. I would order an E38 for a 08 silverado, if you have the VIN where the harness came from I should be able to get you the part number for the E38 you'll need.
Old 04-02-2014, 09:58 AM
BADSZ28's Avatar
Thanks for the reply. I do not have the VIN for the harness. I do know it was an 08. Would an 07 ECM work? I found one of those. I know the service PN is different than the 08 though.
Old 04-02-2014, 10:02 AM
BADSZ28's Avatar
I did post in HPT but nothing back on it. I did search it but minimal info. And mostly about car ECMs.
Old 04-03-2014, 12:01 AM
On a standalone engine swap your TB, gas pedal, and ECM have to all match. The harness isnt really the issue IMO. Are all your parts off a 08 silverado? Where I see issues the most is when people get mismatched parts from salvage yards or just not knowingly mix up those parts.
Old 04-03-2014, 08:25 AM
BADSZ28's Avatar
Harness and pedal are both from Gen 4 trucks...no ECM yet. I know the cable is from an 08 Silverado. I think the pedal might be from an 07 truck. Need to check again. No ECM yet. TB is from an LS3 or LS7. I was under the impression these can be swapped without an issue. Maybe I am mistaken? the deeper I get into this project, the more confused I become.
Old 04-03-2014, 08:41 AM
BADSZ28's Avatar
Looks like all 07+ truck pedals are the same...at least till 11. So I am best getting the 07 or 08 ECM? But those are different. Will the LS3 TB work with those ECMs? I think the service PNs are the same for car and truck respective to year. But then do I need a specific OS to match them all? Then what MAF do I run? I assume I can run any Gen4 knock sensors, cam and crank sensors as well as MAP sensor.
I really appreciate your feedback and responses.
Quick Reply: E38 Revisions?
