Need 98 camaro 3.8 ecm pin out
Old 04-02-2014, 03:33 PM
92rspowerdbyvortec's Avatar
Default Need 98 camaro 3.8 ecm pin out
I'm trying to find the ecm pinout for a 98 Camaro 3.8 because my girlfriends cars aldl port does not work the 2 grounds and the 12 volt supply to it are good so I was going to try and find the data wire from the ecm plug and jump it to my scanner and see if I can reed the codes that way. Thanks for any help in advance.
Old 04-02-2014, 04:05 PM
toplessHO's Avatar
its the same serial data thats thruout the car
should be a splice pack under the dash that is a junction for all serial data.
thats normally where I start when trying to diagnose serial data problems.
I ll see if I can look up the location for you.
If you need an ECM I have one just PM me,I think 98s were one year only.
Old 04-02-2014, 04:34 PM
Ok thanks any thing would help at this point.
Quick Reply: Need 98 camaro 3.8 ecm pin out
