VATS Removal question.
Nearing completion of my LS2 into RX7 FD. I know I will need to remove the VATS but the question is should the engine start without VATS removal. I seem not to have power to coils or injectors ? Thanks for any advice.
It's an E40 ecu. I'm told on another forum that I will not get any response without VATS removed so perhaps it's an ecu thing?
I'm using the stock engine loom so really just adding 12v power and rewiring starter circuit. Although I will recheck power supply is still there during cranking. Thanks for any input. Kev.
i had the same problem with mine. no fuel pump signal, spark, or injector pulse. i had a bad ground. cleaned, relocated, crank crank boom. also with an e40 ecm, but vats had been removed.
Checked power when cranking and ecu getting power. Injectors/coils have their own feed via a connector on the engine loom. So maybe the E40 ecu with VATS enabled will not allow engine to start at all.
