What do you think abou these LTFT's?
Old 04-07-2014, 08:48 AM
MN_V's Avatar
Default What do you think abou these LTFT's?
Vehicle is a 06 LS2 CTS-V.
Mods are headers, high flows, standard 2.5" size magnaflow exhaust.
PCM is mail order tune from Jesse Bubb / Wait4Me.
Had it dynoed last year it was a little lean above 4500rpm around 13.2 so he asked I send it back in to him, which I did. Car runs fine but started datalogging and LTFT's on both banks are averaging about +9.5-11 over multiple 30 minute drives. I don't know if he did something to tune it that way to dump a bit more fuel when in open loop/WOT. STFT typically stay within +/- 5.
Should I be concerned or look into a retune? Thought I would ask around in addition to talking to Jesse later. Car makes good power according to my 1/4 trap speed. MPG is as-expected I would say. Car smells a little rich at idle but not obnoxious.
Thanks for any advice. I am not a tuner and don't know much about it other than the basics of how STFT and LTFT work.
Old 04-07-2014, 01:21 PM
danieloneil01's Avatar
Do you log the car and send him the file for him to make adjustments?
Old 04-07-2014, 01:25 PM
MN_V's Avatar
That's what I'm looking to do. Just got the logger. Are .lgf files a standard format that can be sent to any tuning software?
Old 04-07-2014, 07:17 PM
Doubt it. I would strongly suggest taking it to someone local to dyno and street tune it or buy bptuners and do it yourself.
Old 04-07-2014, 07:35 PM
Iam Broke's Avatar
You can use either DashCommand or ScanXL from a google search. I suggest you find a local or email tuner that uses HPTuners.
LTFT's should be able to be dialed in to +/- 2 pretty easily with a little logging and tweaking.
Old 04-07-2014, 08:28 PM
Russ K's Avatar
I always disable the LTFT's on the Gen IV pcms. As either negative or positive LTFT's will be added to the WOT fueling.
Russ Kemp
Old 04-08-2014, 06:07 AM
redtan's Avatar
Negatives won't, but positives will.
That's why most people shoot for negative long term trims.
OP that's enough of a swing to warrant a re-tune. Generally trims under 5 are accepted, especially with a stock cammed car. Over 10 is just a tune that needs finishing.
Old 04-09-2014, 02:31 PM
MN_V's Avatar
Thanks for the comments. Jesse and I conversed. Before I do any re-tuning I'm going to change the plugs and maybe try a buddy's MAF to see if any of that is causing the issue. Car has 108k on it.
At >~30% throttle the LTFTs switch to 4-7% I have noticed. Only at idle and steady/light cruise when they go up around 9-11.
Old 04-09-2014, 07:05 PM
Old Geezer's Avatar
What Russ said^^^^^^^^^
We just had Vengence Tuning, [Mike Carnahan], dyno our latest project.
L92, mild cam, headers.
400/400 at the wheels. First thing Mike did was disable the LTFT's. And, they are still off.
Old 04-09-2014, 08:12 PM
My LTFTs are turned off too but I use STFTs. Won't the MAF need to be recalibrated?
Quick Reply: What do you think abou these LTFT's?
