no Communication from my snap-on scanner pics included
snap-on says no communication...i checked the data wire from the pcm(green) but the wire coming off the DLC is purple...well that wire goes to this plug and so does the green wire wth???
ok thank you, I put the data wire straight from the pcm to the dlc still got no communication... I will see where the rest of the wires go and what they do. and my old scanner only goes to 99 but it should do OBDII basic for just codes...mite have to use a diff scanner to see what it will do
omg i'm a *** I wait out and rechecked it, I left the red lead in the 12v const port while I checked both grounds and the signal ports....ok I have 12v at the orange, both grounds checked out good and I got nothing from the purple, which is the way it's suppose to be. i.m going to have to get a new scanner and see if it will work
scanner doesnt care if its one year older
I dummied up a spare BCM I have here and it got 8.6v at serial
I will check one thats operating and see but voltage should vary
Im thinking from 0-5vdc on comm line
what model of scanner and what module are you using?
Im using MT2500 with the latest (last one) black cartridge
MT2500 with the troubleshooter cartridge mt25002999/primary cartridge mt25001099 with the obd2 conn. with key2 so i should be able to at least read codes... both cartridges only goto 99 i even try'd to trick it and put in a vin# and it still said no comm??? by the way thank you for your help!
