How to log AFR with wideband and HPT
Old 04-14-2014, 07:19 AM
RENE'S RAGE's Avatar
Default How to log AFR with wideband and HPT
New to all this, I have a standard HPT and a AEM Wideband.
I have the wideband hooked up to my EGR wire.
What do I do next to log the AFR ?
Thanks
Old 04-14-2014, 08:32 AM
LsoneGT's Avatar
http://www.thetuningschool.com/support/free-downloads/
Just click on the site and follow the steps.
Old 04-14-2014, 09:25 AM
Thank you Sir!
Old 04-14-2014, 09:32 AM
LsoneGT's Avatar
Your welcome!
Old 04-15-2014, 07:49 AM
Started on this last night, got to download the excel spreadsheet today.
How do I get the tuner to read the Wideband using the ERG wire.
I read step by step, but didn't see anything about converting the EGR to read
The Wideband.
Old 04-15-2014, 08:28 AM
LsoneGT's Avatar
Im not sure on that one I didn't go that route
Old 04-15-2014, 12:26 PM
S8ER95Z's Avatar
http://www.hptuners.com/forum/showth...nd-through-EGR
A lot of reading but I believe that is what you are looking for.
Old 04-16-2014, 02:34 PM
Thanks, after some research I found that thread also.
It help a lot.
Old 04-16-2014, 08:33 PM
We'll we tried, can't get it to read.
But, first time we had the tuner up and running, pretty cool!
Going to be fun when we learn how to use this thing.
Rene', my wife, is doing all this for me. Hell she even changes the plugs for me. LOL!
Old 04-16-2014, 08:44 PM
Iam Broke's Avatar
After you get it wired up you will have to enable the EGR in the tune. Before you change a thing, do a read entire of the stock tune and save the file several safe places and an extra on a flash drive off site somewhere, maybe a copy on Google drive. When you change the tune do a write calibration, not write entire unless you are changing ECU operating systems.
I used the EGR input on my '02 WS6 and it worked well once set up properly.
Old 04-16-2014, 10:21 PM
GTA91's Avatar
Works great on my '91 GTA with a 402ci LS2 running a '98 LS1 PCM and harness along with an LC1 wideband.
Basically you feed your wideband's 5volt signal back through the EGR wire to the PCM, enable the EGR, create a custom PID, and go from there. I'd have to look up more details, let me know if you can't figure it out.
Old 04-17-2014, 07:51 AM
Yeah, I got it wired up to the EGR signal wire.
Don't know if we created a custom PID .
Going to the track tonite for some shakedown runs. And to log some runs.
We'll get it figured out.
I appreciate all y'all help.
Old 04-18-2014, 02:10 PM
I think I got one run logged last night. Haven't pull it up yet.
But best run was a 10.11 @ 131xx. Bouncing off the rev limiter around the 1200' mark.
7500 rev limiter, guess I need to bump it up some. LOL.
Old 04-18-2014, 02:28 PM
LsoneGT's Avatar
Nice man car is rolling!
Old 04-18-2014, 04:42 PM
Thanks, going to an 1/8 mile track tomorrow.
Old 04-18-2014, 04:48 PM
LsoneGT's Avatar
Yea that's how I roll lol
Old 04-19-2014, 07:36 AM
Tampa Tuning's Avatar
Originally Posted by Iam Broke
Before you change a thing, do a read entire of the stock tune and save the file several safe places and an extra on a flash drive off site somewhere, maybe a copy on Google drive. When you change the tune do a write calibration, not write entire unless you are changing ECU operating systems..
Best advice of the day. Save your stock calibration to several different medias
When I take my own cars out for a cruise and if I make a change to the calibration, I date the tunes 01/01/2014 A, 01/01/2014 B, 01/01/2014 C, so I know which change I like better and not figure out what I did after 10 changes.
Quick Reply: How to log AFR with wideband and HPT
