94 z28 pcm swap into 1995 T/A
I have a 1995 pontiac trans am with 2.73 rear auto trans and I want to swap out my gears for a 3.23 that I have on the side from a 94 camaro z28 auto as well as the pcm out of it. will the pcm swap work without issues or would it still need programing being it came from another car?
Well I plugged it in and started the car but didnt drive it yet revs are where they should be but theres a ses light on. I dont have a code reader handy. Could it be because of the difference in VIN's? Anyway I put the old one back and started it and ses light went away
Im curious as in what slight difference in calibration there could be other than the performance transmission calibration button on my console. If thats all there is I can live with that. My next question is can I drive it like that without hurting anything other than my fans be always on? And thank you for all the replies everyone.
I need to compare the tunes from both cars to tell you.
Are your fans always on? If they turn on as soon as the engine starts then you have another problem not related to the tune
The performance trans tables are in both Camaro and TA files. They are just not used in the Camaros. I know of no differences in the Camaro and TA tunes. The only differences if both pcms are from auto cars would be the speedometer settings, the shift tables, and the converter lock up tables. Get the code read. Setting some codes will cause the fans to run all the time. Is there no one around you with Tunercat and a OBD1 cable that can just change your original PCM? They will need the OBD2 adapter that the 95 cars use.
