no idle in park or neutral
Old 04-21-2014, 06:47 PM
outwest51's Avatar
Default no idle in park or neutral
hi, i purchased a ls6 out of a cts-v cad. it had an standard tranny. i instauled a 4l60e. got a harness and ecm redone. it starts but dies when i put it in neutral or park. runs just fine in drive or reverse. i had a friend hook up a scanner and he says the ecm is calling for 0 idle speed in park and neutral. it is normal in drive and reverse. pulling to a stop sign all is normal and idles fine. anyone ever have this problem?
Old 04-21-2014, 06:58 PM
outwest51's Avatar
oh, i forgot, i have tried two ecm both with the same results.
Old 04-21-2014, 09:21 PM
LSX Power Tuning's Avatar
Has it been tuned or you just trying stock ecm's?
Old 04-22-2014, 07:53 AM
outwest51's Avatar
both ecm's were stock tune except for the normal, theft removal, gear ratio, down line o/2 removal. both were from am cts-v with the correct service number. also this car is a drive by wire and all that is retained. the throttle works just fine. i can keep it running in park and neutral but i have to hold open the throttle just a tad and it runs and idles fine!
Old 04-22-2014, 10:18 AM
Moderator
jimmyblue's Avatar
There are various running airflow tables that have different
in-gear and P/N rows in them. Maybe one of these has some
dumb values inadequate to support A4 trans pump load etc.,
are either of these donor PCMs from an A4 setup?
Old 04-22-2014, 01:53 PM
outwest51's Avatar
both pcm were from a 2005 cts-v cadillac. one from the original car. not sure what A4 setup is, sorry.
Old 04-22-2014, 02:47 PM
thunderstruck507's Avatar
A4 is a term used to mean "automatic 4 speed"
M6 is "manual 6 speed"
Old 04-22-2014, 05:15 PM
outwest51's Avatar
ok, thanks. yes all 2005 cts-v were 6 peed manual trannys i guess. automatics were not available. so i know one was from the donar car and am assuming the other was a m6 car. but i wanted the 4l60e. i am almost done with this nomad and would really love to get this thing to the driver point. just cant get this idle thing fixed.
Old 04-22-2014, 06:36 PM
Old Geezer's Avatar
U wire in the PNP sw on the trans?
Old 04-22-2014, 06:49 PM
outwest51's Avatar
yes. and i tried it with it hooked up and unhooked. i cant tell it makes any difference.
Old 04-23-2014, 01:17 AM
RonSSNova's Avatar
If using a man trans PCM, it has all zeroes in both the idle speed table as well as the base running airflow table for auto trans.
The PCM is just doing what it is told to do
You need to populate those tables.
Ron
Old 04-23-2014, 06:32 AM
outwest51's Avatar
very intresting Ron. i wonder if the place that worked on the pcm can do that or does it take some special software? they never said anything about this and i have been begging them to find the problem! Thanks you, i will ask them.
Old 04-23-2014, 06:42 AM
outwest51's Avatar
i just e-mailed him. hopfuly he will answer. we will see his response.
Old 04-23-2014, 01:34 PM
outwest51's Avatar
Ron, he said he did populate the idle table but not the airflow. he is going to do that and send it back to me. i really appreciate the info. i really have high hopes now.Thank you i am so glad i joined this forum.
Old 04-23-2014, 05:14 PM
RonSSNova's Avatar
Glad I could help!
Ron
Old 04-30-2014, 08:26 AM
Sarg's Avatar
If that does not work, you may be able to have him do a segment swap with an auto car and reflash the tune for you.
Old 05-04-2014, 06:38 PM
outwest51's Avatar
thanks to all. i just got this pcm back and it works perfectly! populating the airflow tables did the trick. i hope this may help someone else with this problem.i was starting to wonder what the heck i would do. sure glad i joined this forum!!!
Old 05-04-2014, 11:26 PM
RonSSNova's Avatar
Yahoo! Isn't it nice when things work like they should?
Ron
Old 05-07-2014, 08:03 AM
outwest51's Avatar
turns out that if you have dbw that the airflow has to be populated. if it is dbc the airflow does not matter! mine is dbw and it needed it because it was originally a 6 speed car and converted to 4l60e. but the dbw was the problem. thanks all
Old 08-19-2014, 08:52 PM
outwest51's Avatar
Default ls6 with 4l60e shift problems
i have more problems with it shifting now. as soon as it moves 20 feet it is in 4th gear already. will not down shift. traveling at 30 mph ground speed the pcm is showing 90 mph. any ideas what to do?
Quick Reply: no idle in park or neutral
