Holley dominator
Old 04-25-2014, 05:47 PM
ws602's Avatar
Default Holley dominator
We're us the best place to get a complete set up from vendors please chime in...
Old 04-25-2014, 05:59 PM
LSX Power Tuning's Avatar
Complete setup of what?
Old 04-25-2014, 07:21 PM
ws602's Avatar
The complete set up for a turbo build.
Old 05-01-2014, 10:30 AM
BMF_Racing's Avatar
Post
The Dominator is sold a la carte' per se. So you would have to order the harness and ecu. From there it is totally optional. If you want to control boost as well you will need two solenoids and a 100psi sensor for Dome pressure. The stanard ls harness will plug into our oem sensors so no need for any other sensors unless you are adding something like a screw in 5 bar Map or a fuel press sensor. Good Luck.
Quick Reply: Holley dominator
