Rev limiter question.
Old 04-28-2014, 06:38 AM
FAD2BLK93's Avatar
Default Rev limiter question.
Just a question, was getting random misfire code a couple of times. If u hit the limiter does it set a random missfire code? Or should i look somewhere else? Maybe new plugs. Thanks. Marc
Old 05-07-2014, 09:35 AM
FAD2BLK93's Avatar
Ttt...anyone?
Old 05-07-2014, 10:24 AM
1slowbusa's Avatar
What is the vehicle and what are the mods?
Old 05-08-2014, 08:52 AM
FAD2BLK93's Avatar
2000 camaro, 5.3, LS1 cam, headers, P&P TB, SSRA.
Old 05-08-2014, 04:50 PM
Cosmik de Bris's Avatar
I don't think so, at least when I've hit the limiter it hasn't. I'd look at the plugs, make sure the coils are seated on the plugs correctly etc.
Old 05-09-2014, 12:29 AM
MontecarloDrag's Avatar
The only way a rev limiter can trip a misfire DTC is when you use an external box to cut spark, like a MSD 2-step or wot box.
The stock limiter cuts fuel and never trips the misfire DTC.
If you have no external devices to cut spark, then you have another issue like floating valves or ignition problems
Old 05-09-2014, 06:50 AM
Tampa Tuning's Avatar
After adding a cam, you may have to increase the misfire cycles about 10%. You said you added new spark plugs, that also could be the problem if a wire is loose.
Old 05-09-2014, 08:46 PM
FAD2BLK93's Avatar
I plan to add a cam next year...havn't changed plugs yet but they are old ones. I think i will change them out and see. Thanks for the replies guys.
Quick Reply: Rev limiter question.
