e40 ls2 ve and maf tuning-pid scanner setup help
Old 05-12-2014, 10:55 AM
95bowtie's Avatar
Default e40 ls2 ve and maf tuning-pid scanner setup help
Been thehing hpt forum and can't seem to find a solid guide on how to set the scanner up properly to log afr error or whatever I need to log properly to get the VE table dialed in using the copy paste special feature.
Also it seems once the VE is all done there are other MAF error pids that can be setup and logged to dial in the MAF hi/lo tables using copy-paste special from your logs.
The car has a AEM wideband installed that I will be using to log afr with.
I've had a thread open for almost 2 weeks now on hpt forum with no responses. So if anyone here can lend a hand a share some info to get me going in the right direction id much appreciate it.
Thanks
Quick Reply: e40 ls2 ve and maf tuning-pid scanner setup help
