Weird thing happen tps sensor
So pull out and I give bout 1/2 throttle and it shifts at 3000rpm which I thought was weird. Then my convert or wouldn't lock up and then I had a miss.
So I stop check logs and it says tps sensor performance. So I clear it and resnap in the connector. So started it up the code went away but I have a bad miss now and also have a code for low voltage on bank 2 sensor 1.
Do you think it fouled out my plugs when the tps sensor went out?
I have no gas in oil or oil in water so I'm thinking I have a fouled plug.
Shows no misfires at all in logs when it's doing it or knock.
What you guys think?
